Reclaimed Lumber Refurbishing?
skyreep
Favorite Zombie Movies: 28 days later, 28 weeks later, night of the living dead, dawn of the dead, REC
Post by skyreep » Wed Sep 07, 2011 8:26 am
Out here in North Carolina (Tobacco Country) we have loads of old tobacco barns that are rotting away, some that are built with planking and others that are built with logs. So I'm curious, how can you take old gray barn planking Image
And turn it into this...
Is it possible? I'm wanting to take some reclaimed tobacco barns and apply it to this style house :
Is it possible?
If not than what kind of reclaimed lumber would you use?
The NSA in Action
NC EMT-Basic
AHA CPR/Healthcare Provider
68W Healthcare Specialist Medically Retired
phalanx
Re: Reclaimed Lumber Refurbishing?
Post by phalanx » Wed Sep 07, 2011 10:06 am
Sure it's possible. But...
You need a planer to thin the boards to get to the fresh, unweathered wood underneath the gray. The thinning process gives you less wood to work with (structurally), but if you're just using this as sheeting or some kind of modified siding than it shouldn't be a big deal. The big issue is access to a planer, and if you can't get that than using a table saw with a good rip fence would work for boards less than 5" wide.
I do this technique pretty regularly on old 2x4's here in Oregon. Back in "the day," house construction materials consisted almost exclusively of old growth Douglas Fir, which has a beautiful grain pattern and a wonderful golden color. I build furniture and doors out of it, so I can certainly tell you that reclaiming lumber is doable with the right tools.
ninja-elbow wrote: ZSC:011 Oregon: We Bug Out wet, dry, at the coast or the high desert ... maybe even the mountains, in a town or in a valley or something....
"We are moral beings only to the extent that we are social beings" - Emile Durkheim
crypto
Post by crypto » Wed Sep 07, 2011 11:16 am
skyreep wrote:Out here in North Carolina (Tobacco Country) we have loads of old tobacco barns that are rotting away, some that are built with planking and others that are built with logs. So I'm curious, how can you take old gray barn planking Image
Is it possible?
Yep, that looks doable. you'll need a planer and a biscuit joiner.
Illini Warrior
Post by Illini Warrior » Wed Sep 07, 2011 4:16 pm
no nails, not going to matter what power tool you choose to use ...... nothing wrong with a planer if working on thicker dimension lumber like 2X, 4X, 6X, ect ect ....... for plank work, a triple head wide belt sander is the tool ..... each head with a different grit of paper ..... load it rough (#40 or #60 grit) and finish with a #120 or finer grit ..... can use a single head and make three/four passes also
Illini Warrior
Spec
Post by Spec » Wed Sep 07, 2011 4:37 pm
I assume you are not using this for indoor facia. Cured tobacco or curing tobacco may have tainted the wood.
A planer is the best tool. Planing short depths at a time rather then trying to do it in one pass.
I would limit the sanding to final pass. It will be a pain.
The pain of discipline is far easier to endure than the pain of regret.
Post by TacAir » Wed Sep 07, 2011 6:06 pm
Cool
My SIL built a shed with OSB, covered with 30 lb tarpaper, then covered with cedar planks salvaged from local fences being torn down.
We just cut the rotted parts at the bottom, then nailed over the tarpaper in a lapstrake pattern. Looks cool, saved a ton of dough and he can claim (at least) part of the shed is "Green"
jamoni
Post by jamoni » Wed Sep 07, 2011 6:11 pm
I have a friend who builds the outbuildings on his farm with salvaged lumber. He'll tear down an old barn for free, haul off the lumber, tin, and whatever else he wants, and burn or otherwise legally dispose of the rest.
Result: two happy farmers, no money spent.
Crazy Wolf
Post by Crazy Wolf » Wed Sep 28, 2011 11:47 pm
Spec wrote:I assume you are not using this for indoor facia. Cured tobacco or curing tobacco may have tainted the wood.
Hmm, would tobacco-tainted wood be a good choice for the exterior as-is, due to the pesticidal effects that tobacco has? Maybe it'd reduce the risk of termite damage.
Nim's text key: SARCASM, WTF R U DOIN, Nice, I like, Inane statement
The phrase "surgical strike" might be more acceptable if it were common to perform surgery with high explosives. (G. Carlin)
m ellis allen
Post by m ellis allen » Thu Sep 29, 2011 7:02 pm
or get the termites hopelessly addictied to you house..........
zombies are notoriously bad drivers
lunicy wrote:Mosins doesn't have Kool aid. It would have to be vodka and coffee,mixed with cosmoline, made with mud, in a hat. Mosins are too rough for kool aid.
RoneKiln
Post by RoneKiln » Mon Oct 03, 2011 12:32 am
Sealing the boards would also seal up any scariness from the tobaco. If you're using it for exterior siding, I don't think it makes a difference. Just finish it with whatever you normally would have.
The greater concern would be breathing the stuff while planing and sanding it. Go get a good filtration mask. The real good ones aren't that expensive and will be worth every penny.
--Raptor
run faster
Post by run faster » Mon Oct 03, 2011 5:48 pm
Ive always wanted to do flooring like this :)
Anything is possible, with the right tools!
southalabama
Post by southalabama » Wed Oct 05, 2011 3:11 pm
take a pressure washer to the old wood, it will do wonders and no sawdust.
