Space Debris
A place for prepping related news stories, video channel links, podcasts, and other media not covered elsewhere in the forums
Space Debris
Post by MPMalloy » Sat Sep 22, 2018 12:37 pm
1. Space Debris is a problem.
From ABC (Australia): Scientists launch net from International Space Station satellite to capture rocket and spacecraft junk orbiting Earth
Scientists launched a net into space to demonstrate how old rocket and spacecraft parts orbiting around the Earth can be removed.
In the British-led experiment, a large net was cast from a mini satellite named RemoveDebris, which was originally launched from the International Space Station in June.
The 5-metre net successfully travelled around 6 metres and wrapped around its target, a boxy microsatellite called a CubeSat, that had just been deployed as part of the test.
Texas-based company NanoRacks, which developed the microsatellite deployer, captured the launch on video and published it on Twitter.
"This is not sci-fi. We repeat, not sci-fi," the company said.
University of Surrey Space Centre director Guglielmo Aglietti said the target was spinning faster than expected, but that made the test even more realistic.
The objective of the demonstration was to show ways of removing debris, such as old rocket and spacecraft parts, from orbit.
This debris poses a hazard not only to the International Space Station and its crew, but to the Hubble Space Telescope and other satellites.
The net and its target will eventually fall out of orbit together and burn up.
Meanwhile, a space harpoon will be tested in a similar manner in February, Professor Aglietti said.
Re: Space Debris
Post by NT2C » Sat Sep 22, 2018 12:54 pm
Okay, how exactly does this help? It seems all the net does is wrap around the debris, doing nothing to retrieve it. Sure, it's going to affect its orbit slightly but I'm not seeing the benefit here. You have to get the net up to the debris, which means with another spacecraft, adding more debris in orbit as shields and stages separate, and even if you capture that one piece of debris and manage to change its orbit enough to bring it down, you've only exchanged it for the satellite that carried the net into position. :?
Also, I think this would fit better in Off-Topic, so that's where it's going.
Re: Space Debris
Post by MPMalloy » Sat Sep 22, 2018 1:09 pm
NT: I think that this fits in CP&P, if for nothing else, to start a discussion of this concern. I agree with all else.
Re: Space Debris
Post by Stercutus » Sat Sep 22, 2018 1:11 pm
The net was launched from the ISS, not Earth. They don't need all the other stuff. Planned properly there should be less debris in space.
The space junk issue has been out there a while. Awareness was raised after China tested it's space weapon a few years back and destroyed a satellite in orbit completely annihilating an orbit path.
Not sure how I can plan for that. Someday there may be no satellites? On a long enough time line that is virtually certain.
JayceSlayn
Re: Space Debris
Post by JayceSlayn » Sat Sep 22, 2018 1:32 pm
One of my favorite space debris solutions was using a ground-based (or space-based) laser to alter the orbits of debris, and eventually cause them to de-orbit. It seems like the most practical, because it can work from a long distance, and target virtually all sizes of debris. Getting a laser powerful enough to alter the orbits of tiny bits of debris is relatively easy (like paint flecks etc.), but getting one powerful enough to meaningfully alter orbits of larger pieces from the ground is a bit more difficult (like wrenches and up). You don't have to get it done in a single go through, and for larger pieces you could alter it a bit each time if flies by. I think the vast majority of debris is the smaller stuff though, so it would at least tackle part of the problem, but the largest things (like entire defunct satellites) may need to be towed down by another solution.
I think the biggest concern would be other countries not wanting you to have a powerful laser capable of blinding satellites etc.
SCBrian
Re: Space Debris
Post by SCBrian » Sat Sep 22, 2018 4:46 pm
One man's junk comes to mind.
Who makes the distinction on what is "Junk"?
Is this satellite really dead, or is it a weapon in sleep mode.
Also on a practical matter, since some of the satellites are nuke powered, what about debris from re-entry. Same with some battery powered ones...
I dunno, getting the trash out is a good thing, but it's riddled with issues...
I tilt at Windmills
Re: Space Debris
Post by flybynight » Sat Sep 22, 2018 5:12 pm
Most of the junk is booster stages and things like that I believe. Weapon in sleep mode would still be monitored/tracked and able to wake up to maneuver ( otherwise why have a sleep mode?) Minimum size for asteroids to make it through the atmosphere and strike earth is about 25 meters. Asteroids would be generally more dense than satellites so most satellites won't reach the ground I guess
Re: Space Debris
Post by MPMalloy » Sat Sep 22, 2018 10:12 pm
Sometimes a functional satellite is replaced by a newer model, & The old one is kept around in a standby mode. Wikipedia has some interesting articles on this.
Re: Space Debris
Post by NT2C » Mon Oct 22, 2018 2:11 pm
Moved to Prepping News
Re: Space Debris
Post by MPMalloy » Mon Oct 22, 2018 2:14 pm
:clap:
Zed Hunter
Re: Space Debris
Post by Zed Hunter » Mon Oct 22, 2018 9:12 pm
A lot of worry over Space Lab's nuclear reactor when it de-orbited. It hit open ocean.
Re: Space Debris
Post by MPMalloy » Mon Oct 22, 2018 9:28 pm
Graveyard Orbit
Spacecaft Cemetery
Return to “Prepping News”
