It is currently Fri Sep 19, 2014 4:46 am
Post new topic Reply to topic  [ 12 posts ]
PostPosted: Mon Apr 18, 2011 5:48 pm
I'm new to the "AR-15" world so please bear with me on this I have an AR-15 with the 16" barrel and the short fore-end . I am looking to put a rail on that has the Picatinny rails. My question is- can I put a "Rifle" size fore-end on a short barrel? I've seen them with a long rail that has an opening for the front sight but not sure of what they are. Ideas? Thanks. :?:
PostPosted: Mon Apr 18, 2011 5:50 pm
http://www.bravocompanyusa.com/Tactical ... ds-s/7.htm
Pick one..
sigboy40 wrote:
I carry around magical kit faeries that keep all my stuff in place. This way I dont lose anything.
CEO of http://movementtocontact.com/index.html
PostPosted: Mon Apr 18, 2011 6:00 pm
these 3 from GD4's link specifically fall meet criterion of a cutout for the sight
http://www.bravocompanyusa.com/Daniel-D ... 0black.htm
http://www.bravocompanyusa.com/Daniel-D ... %20fde.htm
http://www.bravocompanyusa.com/Daniel-D ... 010005.htm
Jungle Recon Trooper wrote:
Biggin wrote:
praharin can be an insufferable dick
Adding as many ponies to as many threads as humanly possible.
PostPosted: Mon Apr 18, 2011 6:01 pm
Thanks! :D
PostPosted: Mon Apr 18, 2011 6:13 pm
Here's the short layman answer:
Yes, but it's expensive.
Normal railed handguards still "clip on" to the rifle, using the factory delta ring, and the sheet metal bracket right behind the front sight tower.
If you want a rail longer than that, it will have no forward attachment point. So, you'll need a free-float handguard.
These involve removing the factory (spring-loaded) delta ring that holds factory-type handguards on, and replacing it with a large fixed, threaded nut that engages the free-float handguard more firmly, and clamps it against the receiver.
This allows you to hold the weapon by the handguard which is only attached to the rifle on one end, and bang it around, without upsetting the handguards mount.
The obvious question, though, is why you want a longer handguard on a carbine? how much shit are you going to put on the rail system?
If you just want something that projects further forward, like a weapon light, there are many good small rail sections that bolt through sides of the front sight tower and give you about an inch of rail on either side. Midwest industries makes a good one: http://www.midwestindustriesinc.com/ind ... gory_id=94
At $35, its far cheaper and lighter than a free-float handguard, and if you're just looking for somewhere to put a light or laser, its a far better solution.
PostPosted: Mon Apr 18, 2011 7:51 pm
You can swap the delta ring out and install a yhm rifle length rail. I have and it leaves 4" of barrel out front. It gives you a long sight radius if your using iron sights. Other than that you have a lot of real estate to use. I pitched mine for Magpul moes. I still have a rifle rail on my sons rifle. I'll post pics later.
A vitiated state of morals, a corrupted public conscience, is incompatible with freedom.
Pleasure Island is a metaphor for the “profane life” characterized by ignorance, the search for instant gratification and the satisfaction of the one’s lowest impulses ~ The Esoteric Interpretation of Pinocchio
GIVE US STUFF! GIVE US STUFF! GIVE US STUFF!
PostPosted: Mon Apr 18, 2011 8:00 pm
thread hijack in progress.
I want this http://www.bravocompanyusa.com/Troy-TRX ... 20s3bt.htm
To replace the rails currently on my AR which are heavy as shit YHM rails from 07.
PostPosted: Mon Apr 18, 2011 8:28 pm
Regular Guy, GD4: you're missing something important:
He's not removing his existing gas block to mount a low-profile one, and he specifically wants a cutout for his existing A2 front tower. He will not realize any longer sight radius with a rail.
also: god I cant imagine how heavy the YHM rifle rail is. The YHM carbine rail I had felt like a cinder block on my rifle. Went with MOEs for weight.
PostPosted: Mon Apr 18, 2011 8:33 pm
I used the lightweight yhm rail on my sons. Between it and the moe rifle is a half pound.
PostPosted: Mon Apr 18, 2011 8:41 pm
Take a look at Daniel Defense Omega X 12.0 FSP:
https://danieldefense.com/rail-systems/ ... rbine.html
https://danieldefense.com/rifles/carbin ... ne-v1.html
But do you really have a need for it? Is it to look good or to be able to place your hand further to control the rifle better, attach a flashlight and other accessories?
Warning; this post may contain text matter not suitable for the weak-minded or immature thinker. Reader's discretion is advised.
PostPosted: Mon Apr 18, 2011 8:53 pm
He's not removing his existing gas block to mount a low-profile one, and he specifically wants a cutout for his existing A2 front tower. He will not realize any longer sight radius with a rail. I know and I dont care!
I also have carried a 203 very extensively so the extra weight did/does not bother me. BUT I only mount a light, sling, and vfg so all that metal is now weight slowing me down.
PostPosted: Tue Apr 19, 2011 3:53 pm
@launchteam; This is the one you want if you're not looking into doing a lot of "gunsmithing". The Troy MRF system utilizes the original barrel nut(you just cut away the Delta-ring). Not to expensive either.
Thomas
RIP hk33k
Users browsing this forum: Exabot [Bot] and 5 guests
